2003 Chevy Express VSS wire
Old Apr 5, 2016 | 4:27 PM
banner1124's Avatar
Default 2003 Chevy Express VSS wire
Just wondering if there is access to a VSS wire inside the vehicle? I'm likely going to be upgrading my head unit to one with navigation and would like to, if possible, tap into the VSS wire but that's most feasible if there's access someplace inside the van.
Old May 2, 2016 | 8:40 AM
banner1124's Avatar
OK, so I now know there is no access to that wire inside the vehicle so I'll need to tap into it under the hood and then run a wire inside the vehicle. Here's my question, can anyone tell me where the place one would route from the engine, through the firewall and inside the vehicle is located. I'm fairly certain that there is a spot already there specifically for such routing, just not sure where it is. A photo of what I am looking for would be great. I'm out of town for work at the moment so unable to check it out myself. I'd be great when I get back to already know what I'm looking for instead of having to spend a bunch of time hunting around for the right thing. Thanks
Old May 2, 2016 | 9:29 AM
canucklehead's Avatar
Look around the brake pedal area. there should already be a couple grommets you can fish a wire through without cutting a hole.
Old Jul 27, 2016 | 2:58 PM
banner1124's Avatar
I ended up being out of town for months and just this past weekend finally got around to doing this. Thanks for the advice. There was a grommet right down by the brake pedal that I was able to use. Fished the wire through just fine without cutting any new holes. Hookup worked like a charm. Thanks again.
Old Aug 26, 2019 | 2:05 PM
Jeff Hed's Avatar
Can you tell me where the VSS was found and what color wire? Thanks!
Old Aug 27, 2019 | 12:10 AM
Artie1's Avatar
Why does a radio need VSS?
Old Aug 27, 2019 | 5:11 AM
Speed compensated volume. GM used to put that in the factory decks too.
