2004 Express 1500 resistor pack location.
Old Jul 17, 2013 | 7:35 PM
Rob Udell's Avatar
Default 2004 Express 1500 resistor pack location.
Can someone help me locate the resistor pack in the truck? Perhaps a video link of it? The high does not work but the lower three speeds do work. I've changed the one in my wife's Trailblazer, so my assumption is that, that's the issue. Any help is appreciated thanks in advance.
Old Jul 20, 2013 | 4:44 PM
canucklehead's Avatar
resistor for what.....fan speed?
Old Oct 12, 2013 | 1:22 PM
Okole's Avatar
Sounds like resistor for the fan speeds.
Front or back?
Old Oct 12, 2013 | 1:42 PM
jtho53's Avatar
The fan resistor is located in the plenum under the dash next to the fan. You may also want to check the fan speed switch in the dash cluster.
Old Oct 13, 2013 | 3:12 PM
tsbrewers's Avatar
If your high doesn't work, and the rest do, then it most likely is just a fuse. Check both fuse locations for a blown fuse. The high speed is run directly off 12v and bypasses the resistor IIRC.
Brew
Ignignokt
Oct 6, 2014 3:09 PM
LeeHamilton
Mar 31, 2012 2:26 PM
mcjackson
Mar 3, 2011 6:24 PM
towinnh12387
Feb 2, 2011 10:33 PM
northey87
Oct 15, 2008 7:03 PM
