2005 Chevy Express 3500 (Bus) A/C compressor won't engage
Old Dec 11, 2023 | 11:46 AM
AMAuto's Avatar
Default 2005 Chevy Express 3500 (Bus) A/C compressor won't engage
Had a 2005 3500 come into my shop with some different a/c issues. First issue was it was stuck in defrost mode. Found the vacuum failure at the tank and replaced it. Now the compressor will not turn on when it's turned on. Tested relays and fuses, even replaced climate control. I can use my scan tool to turn on the compressor so I thought the Pressure switch or clutch switch was bad. I replaced them but still no response except when I use my scan tool. Freon levels are fine as well. Anyone else had this issue? (also, I have replaced the mode actuators)
Bigdogdaddy
Jun 8, 2023 11:40 PM
Syncman
Jun 26, 2016 11:31 PM
stallonepanerai
May 18, 2015 10:14 AM
InnerCityHillBilly
Nov 18, 2010 9:35 PM
JimDe
Jun 14, 2010 9:27 PM
