2005 Express 1500 2wd Parking Brake problem
Old Nov 10, 2010 | 5:58 PM
SpudmanWP's Avatar
Default 2005 Express 1500 2wd Parking Brake problem
We have a fleet of 11 2005 Chevy 1500s and a few of them have the same problem.
With the parking brake (rear disk rotors) fully depressed I can spin the rear tires with my hands (jack up in the air). I have not been able to find any kind of cable adjuster for the parking brake. Everywhere the cables connect all I have found was a simple connector, not an adjustment nut, flange, etc.
Old Nov 10, 2010 | 8:43 PM
MDTAHOE's Avatar
Professional Mechanic
You have to remove the rotor. It has shoes inside with an adjuster similar to a drum brake adjuster.
Old Jun 11, 2015 | 7:09 AM
MarknMD's Avatar
I have a 2010 Exp 1500. I adjust the parking brake so there is a little friction when you slide the rotor off and on. even then, I find that the parking brake doesn't do a whole lot of good.
JunoAF
Jun 20, 2015 8:15 AM
bigb
Aug 12, 2013 8:56 PM
jbriggs337
Jan 23, 2013 10:42 PM
jesse06
Aug 12, 2012 5:53 AM
