2006 Express reverse/interior lights
I shorted the wires to my rear dome light while rumagging around in my work van. I cannot find a fuse that corresponds to either the interior lights or the backup lights. Both are non-functional. I've seen this fuse location issue elsewhere but no replies have been posted. Please...help!
The block in the engine compartment doesn't have a fuse designated for this. I checked every fuse that might share the reverse and interior lights-even though the items designated on the fuse schedule worked fine. I will just have to rip out every single fuse and continuity test each one. It's been a little too cold to go through that lately but screw it. I'll post my findings.
The fuse is located under the hood. Remove the fuse panel cover on the driver side of the vehicle. Starting from the upper left corner of the mini fuses, to number fuse 18. Pull that fuse, & I think you will find it has blown. Replace the blown fuse and you should be in business.
Scott Puffenbarger
December 12th, 2015 8:48 AM
