2007 Chevy Express 4.8 engine over heating
Old Oct 16, 2022 | 12:35 PM
Bhrett83's Avatar
Default 2007 Chevy Express 4.8 engine over heating
Help I have a 2007 Chevy express Van That is over heating and I can’t seem to find the problem. I’ve changed the the transmission, ( I thought it might be from torque converter lock up) I also changed the oil pump ,radiator, water pump, Thermostat, fan clutch and I Bled the coolant system and it still over heats.. When the van is idling it does not over heat .. When I drive it for 20 mins it starts to slowly rise in temp to 260 and I shut it off and let it cool off and drive it for another 20 mins and it over heats.
help!!! I’ve thrown every part I can think of and I’m stumped!!!
Old Oct 16, 2022 | 12:43 PM
  • Get a head gasket tester kit
  • pressure test the cooling system
Old Oct 16, 2022 | 1:16 PM
Bhrett83's Avatar
I had a shop pressure test it last month and it held no leak down . That’s why everyone thought it was torque converter lock up or crank case pressure. I changed the 4L80 for a brand new unit and I went through the motor cleaned things and changed new oil pan new melings oil pump and etc
Old Oct 16, 2022 | 1:48 PM
Rednucleus's Avatar
I assume you have verified your sensors & gauges are accurate. Does it boil over/look/smell obviously hot when it spikes?
Old Oct 16, 2022 | 2:26 PM
Bhrett83's Avatar
Yes it boils over .. Definitely getting hot
Old Oct 16, 2022 | 2:51 PM
It could be an incorrect or faulty thermostat, or maybe installed backwards.
Old Oct 16, 2022 | 10:21 PM
Rednucleus's Avatar
Try temporarily runnig w/o a thermostat see if problem persists
DavidDeBord
Apr 16, 2022 8:10 PM
Robert Eric
Jun 7, 2020 11:44 AM
Benjamin Pokol
Dec 5, 2015 11:16 PM
jose emanious
Jul 22, 2012 9:21 AM
antonv
Jul 7, 2011 7:53 PM
