2007 Express 3500 charcoal canister removal (solved)
Old Oct 4, 2023 | 8:42 AM
07Express's Avatar
Default 2007 Express 3500 charcoal canister removal (solved)
Hi, first post here.
My question is regarding how to remove the vapor canister. I have disconnected the hoses, but can’t figure out how to disengage the canister from the support bracket. Other than the two zip-ties, I don’t see any other fasteners. At first I thought that the zip-ties had been added by a previous owner, but it turns out that the GM parts book has a listing for them. The tabs on the bracket (an integrally molded part of the tank) fit into pockets in the top and bottom of the canister. After cutting the zip-ties the canister is a little loose, but I can’t determine how to remove it. I’m guessing that there is a way to “pop” the canister out of the bracket, butI don’t want to force it and risk breaking the bracket. Any tips or guidance would be greatly appreciated.
A few pictures follow:
Canister mounted on fuel tank
Bracket engaging pockets in canister
Old Oct 4, 2023 | 2:05 PM
07Express's Avatar
I figured it out. By flexing the bottom tabs out of the canister, with a large flat blade screwdriver, it came out of the bracket. Just took a little more effort than I was expecting.
Old Mar 28, 2025 | 3:00 PM
Express3500's Avatar
Thanks for the post. I had the same issue. Obviously, bend them back to reinstall? Thanks!!😃👍🏁
Th3Glu3
Oct 20, 2023 6:40 PM
cragar
Aug 21, 2023 10:23 PM
Th3Glu3
Apr 29, 2021 6:29 PM
Resendiz
Aug 8, 2015 9:09 PM
scrnchr
Oct 13, 2012 9:55 AM
