2008 Chevy Express loss of power
Old Jun 3, 2015 | 8:30 PM
Kylebrownell's Avatar
Default 2008 Chevy Express loss of power
I have a 2008 Chevy Express passenger van and recently had an issue where I lost power to the transmission. I was driving around 50mph and was the engine only revved up when I was in drive and pushed the accelerator. The speedometer also read 0mph even though I was still moving. I was able to reengage the transmission by putting it into 2nd. I pulled over, stopped and started the vehicle and then was able to go again in Drive. I had the battery checked and it is good, the fluids are fine and the vehicle was just serviced at a chevy dealer 2 weeks ago (full transmission flush and other services).
Please let me know if you can help. I am driving back from Canada with my family (10 people) this weekend and the only thing the dealer can say is until we can reproduce it, nothing can be worked on!
Old Jun 5, 2015 | 12:30 PM
dberladyn's Avatar
Do you know if your 2008 is drive by wire? Is there mechanical linkage to the throttle system and transmission or is it all electric? If it's all electric like mine... this post scares me.
Old Jun 5, 2015 | 7:56 PM
canucklehead's Avatar
My 2002 has throttle linkage like the old days, and I had to replace the shifter cable. It is mechanical, but the tranny has electric shift controls inside.....
Old Jun 6, 2015 | 7:19 AM
lunghd's Avatar
Originally Posted by Kylebrownell
... and the vehicle was just serviced at a chevy dealer 2 weeks ago (full transmission flush and other services)...
Don't know how many miles you have but on high mileage vehicles I would never flush a transmission... just change fluid & filter and go on. All the crap settles into nooks & crannies that can come loose in a flush... and in turn doesn't all leave the transmission during the flush service. What's left floats around looking for another place to settle into. If that's the transmission filter - great, if not... Hoping this is not related to your issue.
You mention your speedo showed 0 mph so check to make sure the clowns at the dealership didn't damage the transmission harness - there are a few connectors near the pan... although they'd have to work at it to damage them.
On my transmission there is an electric vehicle speed sensor located at the rear, driver side just ahead of tailhousing which is where the speedo, etc get's the vehicle's speed signal.
I would check behind the service guys first to make sure they didn't damage the connector or harness but if the part itself is bad; the VSS is cheap - this is what it looks like (link is to Amazon) but you can get it at any auto parts store: Amazon.com: OEM VSS65 Transmission Speed Sensor: Automotive . (I had to guess at your van's trim details so just take this as an example; even my 2000's VSS looked identical to this one.)
I wonder if they damaged one of the solenoids when they pulled the pan? I also had to replace a solenoid (another cheap part, 2/$25 at Amazon) on my son's car after damaging one when pulling the transmission pan. Damage wasn't obvious at first & solenoid was located where pan would strike it if you're unaware of a 'trick' to getting the pan out easily.
Here is a link to another thread here where someone else had this issue: https://chevroletforum.com/forum/exp...ps-zero-37777/
<script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script><script type="text/javascript">window.onbeforeunload = function() {}</script>
Old Jun 30, 2015 | 6:21 PM
Chromatic 1's Avatar
My father in law van does that it's got to do with the throttle body I believe there is a tsb for it
Old Aug 12, 2024 | 4:05 AM
HandymanInside's Avatar
Look on passenger side of motor and check to see if the wire harness hasn’t fallen down from the plastic retainer failing and began to rub onto the heater hose clip this can short wires and cause an intermittent issue and then completely dissapear like nothing happened. The tachometer twisted pair if shorted will kill the engine intermittent as it rubbed into the hose clip on bumps in road.
Wire harness fastener failure… Tachometer twisted pair shorting on heater hose clip, intermittent loss of power… hard to figure out
justheretohelp
Nov 17, 2014 5:04 PM
Tlindsey099
Oct 7, 2013 10:36 PM
Ibanezadam
Cobalt
May 30, 2013 2:45 AM
s1helby1
May 19, 2009 5:00 PM
rteas48183
Mar 18, 2008 4:59 PM
