2008 Express 1500 cargo - right rear door "open"
Old Apr 19, 2012 | 11:22 PM
PatrickGCU's Avatar
Default 2008 Express 1500 cargo - right rear door "open"
For the last week or so I've been getting a message on the DIC about the right rear door being open. Obviously this is some sort of error. The odd thing is, I only get this message and chime when I am turning left! I have tried cleaning off the contacts on both rear doors but that doesn't seem to work. The vehicle has 75K miles. Any help is appreciated, thank you.
Old Apr 20, 2012 | 10:24 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> PatrickGCU,
This may occur due to an obstruction, another possibility is a wiring issue. These are just suggestions, not a diagnosis. I encourage you to have the vehicle inspected by a certified technician. They will be able to offer more information after physically inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
Old Apr 20, 2012 | 2:40 PM
Scooch's Avatar
Site Ambassador
I'd pull the door switch out and look at it thoroughly, the problem may be in the switch itself, not necessarily the contacts. If thats not it, I'd trace that door sensor wire as far back from the trigger switch as I could go until it goes into the wiring harness in case theres a short where the wire got pulled or something going into the door. Thats just me, I like to exhaust all options before taking it to the shop.
PapaHepcat
Sep 27, 2015 10:42 PM
thompjs
Jul 6, 2015 11:18 AM
blkmage024
Uplander
Jul 22, 2014 11:06 AM
DINOROMEO
Sep 24, 2010 10:09 PM
DonK
May 26, 2010 4:37 PM
