2011 Express 1500
Old Sep 2, 2020 | 10:57 AM
RonB1001's Avatar
Default 2011 Express 1500
Jumped in the van Saturday turned the key and heard click-click click! My first thought was battery,but I saw that the interior lights and headlights were on and did not look dim. Battery is about 3-4 years old. I didn't gave time to mess with it till yesterday and I was going to try to jump start it but when I turned the key this time it started right up. I could see the alternator was charging so I let it run for about 10 minutes and shut it off and tried to restart and it did. I just let it be for a couple of days since I don't drive it much since the pandemic. I tried it this morning, and again it started right up again. I moved it a few feet so I could work on it easier if I had to,shut it off and tried to start it again and I got click click click. My question is could it be the battery? what's throwing me is the lights are not dim at all. cables are tight at the battery. Would a dead cell produce this symptom or is it something else? Any input appreciated.
Old Sep 3, 2020 | 12:58 AM
get the battery tested. Battery retailers usually do it for free.
Old Sep 6, 2020 | 8:19 AM
Kael's Avatar
My daughter's car used to do this all the time and the problem was dirty connectors at the battery. Remove and clean the terminals and connectors with a wire brush, maybe some baking soda solution.
The corrosion may allow enough current for light bulbs and such, but not enough for the starter, so click-click-click.
Oh, and 10 minutes on idle isn't enough to charge a battery much, the alternator doesn't put out as much current at the low RPMs. Check the battery with a voltmeter, ignition off. Should see over 12.5V if it's in decent shape.
Mike_in_Mass
Colorado
Nov 20, 2019 11:04 PM
camperbc
Dec 31, 2013 5:22 PM
Will010574
Jul 9, 2012 2:33 AM
lehtmego
Jul 20, 2010 6:16 AM
toddandtamara
Dec 25, 2008 7:07 PM
