2012 Express stereo replacement
Old Nov 15, 2020 | 8:40 PM
rvguy's Avatar
Question 2012 Express stereo replacement
I have just picked up a 2012 Express 2500, that is your basic fleet van. Crank up windows and basic AM/FM stereo. I was going to install a replacement stereo today, but am a bit confused with the wiring. I've done many stereo swaps, so I am not a rookie. The old radio has 2 connectors, the smaller has 4 wires. The larger has the power, etc. First question, what is the 4 wire connector for? Secondly, I am looking for the wiring convention of the van. Thanks
Old Jan 1, 2021 | 6:35 PM
VanManTyler's Avatar
Great question! I am looking for the same information! I also have a 2012 Chevy Explorer conversion van on the Express 1500 135" wheel base chasis. If you get that wiring diagram, I would love to see it too! Thanks in advance for any assistance you can provide. I am looking to upgrade many aspects of my van audio system, both in front on the dash and in the back on the video entertainment system.
Old Jan 2, 2021 | 12:44 AM
schematics are available on gmupfitter.com.
Likely the small connector is data to enable chimes and Onstar connection.
Old Jan 3, 2021 | 2:10 PM
William Kisselstein's Avatar
Does anyone sell a radio install kit for these vans? I know they exist for 02 and older. Should have a pigtail that the factory harness plugs into and you wire to the pigtail that comes with the aftermarket radio.
I didn't bother with either of mine because the wiring is pretty standard and they're both old hunks of junk and I didn't see the need to spend the extra on.
Old Jan 3, 2021 | 2:37 PM
SteveROntario's Avatar
Yes, I installed an Android system in my parents (now mine) 2004. You need a double DIN bracket, harness adapters, a door chime module, and a radio. Maybe also an antenna cable adapter.
Finagling the cluster cover off is a bit tricky and cramming all of the wiring in behind a big radio is definitely hard.
Mitchell Bentley
2007 - 2013 (GMT900)
Dec 1, 2020 9:25 PM
60wt
Sep 2, 2015 11:26 AM
eddie1220
Aug 19, 2014 11:16 PM
915chev
Oct 8, 2013 4:44 PM
mgiasson01
Sep 15, 2008 8:14 PM
