2015 Express 2500 power mirrors upgrade
Old Jul 24, 2023 | 8:20 AM
stevenp2500's Avatar
Default 2015 Express 2500 power mirrors upgrade
Hello all,
im new to this forum and hoping to share information!
I'm wanting to upgrade my 2500 express to power mirrors. Ive seen video online where its possible but that was for a 2017. I've done a quick search in these forums and can't seem to find revellent information on this topic. Does anyone have some knowledge to share in regards to the appropriate part numbers for the trim panel (to accommodate the mirror control switch) and switch the number?
Thanks in advance!
Old Jul 24, 2023 | 4:27 PM
mirrors are talked about a lot. I'm sure you'll find something if you try the search function.
Old Jul 24, 2023 | 4:41 PM
Triaged's Avatar
Not what you are looking for but I put in a new one with the blinker and heat. Already had power and rear window defrost so it just worked. Only did the passenger because that's the one my wife smashed against a parked F150. Saw some videos where it was a super quick swap on older vans but had to pull the door panel to get to the wire plug on my '15. https://www.gmpartsdirect.com/oem-parts/gm-passenger-side-door-mirror-15227440-84994861
Old Jul 31, 2023 | 8:30 PM
TXLeadfoot's Avatar
This is awesome! Do you have a URL or part number for the left signal mirror?
Old Aug 1, 2023 | 12:39 AM
Triaged's Avatar
It's been back ordered for a while. I'll have to pick one up sometime to make it match the passenger side but might try and find a used one. https://www.gmpartsdirect.com/oem-pa...LXY4LWZsZXg%3D
Edit: RockAuto has aftermarket ones. Not sure if I'd trust them to be as good quality as factory.
https://www.rockauto.com/en/moreinfo...308860&pt=1304
Neesynh10
Nov 2, 2025 8:10 AM
Neesynh10
Jun 5, 2023 9:54 AM
haznavy
19
Jan 15, 2019 3:50 PM
Arthur Gelly
Jun 4, 2016 7:27 PM
07kastenwagen
Nov 25, 2007 9:10 AM
