2017 Chevy Express 2500 Check engine light, service stabilitrak and traction control
Old May 17, 2018 | 7:52 PM
meecho216's Avatar
Newly Registered
Default 2017 Chevy Express 2500 Check engine light, service stabilitrak and traction control
Hello,
I'm new to the forums with a big problem!
My Check engine light, service stabilitrak and traction control all came on and flashing at the same time
Here's the story. I was coming to a stop and applying the brake when I heard 4 chime dings and the check engine light, service stabilitrak and traction control lights all came on blinking
The Information display read "Service Stabilitrak Soon" and "Service Traction Control Soon" I also felt the transmission down shift twice.I came to a stop.
I tried to accelerated forward and i could barely move forward the display read "Engines power was reduced" I was able to get to speed. I pulled over and shut the van off for a few minutes.
The van started but, the engine light and stabilitrak was on. The van ran OK for awhile but, after a few miles the same thing happened.I was able to get home
The next day I took the van to the GMC dealer 4 days later they replaces the TPS sensor above the brake pedal.I picked the van up and with in 20 miles the same thing happened
I took the van back to the dealer 2 days later they sprayed dielectric on some connectors and said it was ready I picked the van up and drove another 20 miles and the problem reaccured
I'm very frustrated now I'm taking it back tomorrow. I let you all know what happens!
thanks for reading
Old Dec 22, 2023 | 6:45 AM
Chenko's Avatar
Default Any results? Any changes? Having same issue
Originally Posted by meecho216
Hello,
thanks for reading
Did you fix your issue? Am having same problem
Old Dec 22, 2023 | 8:29 AM
Triaged's Avatar
Did you scan it and get the codes? What codes came up? Could be corrosion or a chafed wire for the throttle pedal.
Old Dec 22, 2023 | 9:18 AM
Chenko's Avatar
also, it’s hard to start in the morning I have to turn the ignition switch hold it on the opposition and then triggered it for like five seconds until it starts. It only happens when it’s cold. Also transmission only is from 1st to 2nd and he gets stuck on third gear for a while until the shifts and until everything gets warmed up I didn’t transmission oil change and filter.
Old Dec 23, 2023 | 4:35 PM
that person hasn't visited the forum in 5 years so I don't think they'll reply to you.
Please make a new thread that includes your vehicle info and all the troubleshooting you've tried.
Old Nov 27, 2024 | 12:20 PM
Cmoney's Avatar
Default I just purchased a van and am having exactly every single one of these issues
2017 Chevy express 2500
traction control light, check engine light, service stabili track. Won’t shift out of first half the time. Stuck in second or third randomly.
I put in a new battery.
giving codes
P0700 (track control)
U0073 (control modual communication bus “A” off
U0101 (lost communication with Tcm
U0109 (lost communication with fuel pump control module)
can anyone help with this please I just bought this work van and I really need to get it working only has 70k miles on it I can’t believe it’s already screwing me
Old Nov 27, 2024 | 1:56 PM
Triaged's Avatar
It's might be wiring or circuit board corrosion or chafing issue. Could also be some expensive module out. A visual inspection of all your wires and ground straps is where to start. You've got communication issues so their might be a chafed wire putting noise in the system and causing the failure to communicate. Be sure to take the engine cover off and look all around the engine, transmission, and wheel speed sensors.
Take a look at this.
After that you're starting to get into some more advanced stuff. Find wire diagrams and check for power and ground to modules. Hard to do anything past that without some very advanced scan tools. There are a bunch of YouTube videos out there on this.
Old Aug 6, 2025 | 2:51 PM
Josh haire's Avatar
Default Did u get it fixed
Mine is doing the same thing and I'm stuck a 1000 miles from home
Khalid Sherer KS
Jul 27, 2019 6:15 AM
Chevy fan no more
May 30, 2017 3:44 PM
colton222
Feb 13, 2016 6:15 PM
Waddy
Oct 13, 2014 6:36 PM
dkennedy
Nov 1, 2012 12:00 AM
