2024 steering wheel audio controls
Old Apr 5, 2024 | 7:39 PM
urwuis's Avatar
Default 2024 steering wheel audio controls
24 express has been built on on its way to me. Bare bones audio choice, and obviously without steering wheel audio controls. 1} upgrade audio 2} new steering wheel. How difficult will this transition be? Thanks for reading and your advice!
Old Apr 7, 2024 | 8:30 PM
Triaged's Avatar
It's remove and replace if you get the whole wheel. It's remove horn/airbag, remove wire harness, cut hole, install switch, install wire harness if you want to just add the switch to your wheel. Pictures below of parts and where they go. I'll be doing this when I get a bit more time.
Steering wheel audio controls wire harness
Steering wheel audio control switch
Cut hole here
Poke here both sides to remove airbag/horn. Follow safety instructions.
Old Feb 20, 2025 | 5:01 PM
cobbenterprises's Avatar
Default Update?
Were you able to get the controls installed? Is it easier to buy the whole wheel or buy the controls and harness?
Thanks.
Old Feb 20, 2025 | 5:42 PM
Triaged's Avatar
Likely easier to buy the whole wheel. I haven't gotten around to cutting the whole for the switch to mount. Too many projects too little time.
Ken Czarnecki
Feb 19, 2019 8:10 AM
heavy chevy09
Dec 11, 2011 4:49 PM
bschnacker
Apr 3, 2011 10:46 PM
swak
Jan 1, 2008 9:15 AM
