6.0L timming marks, help
Old Nov 3, 2013 | 1:24 PM
stevenh's Avatar
Default 6.0L timming marks, help
I have a 2009 gmc van with the 6.0l engine, it broke the cam gear alignment pin and spun the gear. I have replaced the bent vales and have new timming chain and gears but I don't know which mark on the cam gear is the timming mark. any help thanks
Old Nov 3, 2013 | 9:13 PM
rynmcdonald's Avatar
Here's a picture. Notice the notch at the bottom on the cam gear and there's a notch at the top on the crankshaft gear. Make sure piston 1 is at TDC before you install. The crank key usually points toward 1 when at TDC.
Last edited by rynmcdonald; Nov 3, 2013 at 9:17 PM. Reason: Additional information.
ALPHADOG707
Aug 15, 2024 11:24 AM
metalman1232
Feb 24, 2014 12:16 AM
ALPHADOG707
Oct 21, 2013 4:24 PM
sandman608
May 11, 2010 9:35 PM
Nutt79
Feb 7, 2009 4:31 PM
