97 Express 3500 Fuel Pump Intermittent Problems
Old Jan 11, 2014 | 11:58 AM
pathach5150's Avatar
Default 97 Express 3500 Fuel Pump Intermittent Problems
97 Express 3500 with 454 ci engine. Replaced the fuel pump and pressure regulator and now it starts intermittently. Sometimes it won't start but I let it sit for a half hour or so and it starts. Sometimes I get no hum from the pump, I can bang on the fuel tank and it kicks in and starts. I had it scanned and showed code for throttle positioning sensor. Any help would be appreciated.
Thanks
Old Jan 11, 2014 | 4:06 PM
canucklehead's Avatar
try swapping the fuel pump and starter relays. They are the same. If it improves there is your issue. If however the new pump is faulty.....( was it new or a used part?) Then it might need doing again.....
I have heard stories of new pumps only lasting a few months...which sucks for sure.
Replace the tps if its bad. Computers don't work well with faulty input readings.
Old Jan 11, 2014 | 4:15 PM
greenfire's Avatar
454,, that thing must haul ***... good luck with your repair.
chris 419
May 18, 2013 10:29 PM
mscorpion75
Feb 9, 2013 1:18 PM
hunter10220
May 18, 2011 8:37 PM
ed1le
Apr 17, 2010 7:41 AM
warrennaujalis
Oct 28, 2006 10:24 AM
