99 express 3500 intermittent start please help
Old Sep 4, 2019 | 6:14 PM
Cliff1985's Avatar
Default 99 express 3500 intermittent start please help
Originally thought fuel pump was bad . Replaced fuel pump with same problem. If I leave the battery unhooked for several hours van will start and run for between 2 and 10 minutes and then the fuel gauge pegs out and engine shuts off and I loose power to fuel pump and coil until I disconnect battery again .
Old Sep 6, 2019 | 3:22 AM
Jennitran's Avatar
Originally Posted by Cliff1985
Originally thought fuel pump was bad . Replaced fuel pump with same problem. If I leave the battery unhooked for several hours van will start and run for between 2 and 10 minutes and then the fuel gauge pegs out and engine shuts off and I loose power to fuel pump and coil until I disconnect battery again .Visit this link to know when is replace car battery.
Using OBD2 scanner to diagnose to know what wrong with your car before replacing anything. I think it maybe a low battery charge. You should check the battery, alternator, battery cables and wiring if one of them has issue or not.
Old Sep 6, 2019 | 12:33 PM
Cliff1985's Avatar
No codes on scan . I’m thinking probably ecm but I don’t know if there is a way to test it before I buy a new one and if anyone knows where there may be problem prone wiring on this particular model . Battery and battery connections are all good.
Old Sep 6, 2019 | 3:06 PM
loopedr1's Avatar
it sounds like a security issue....that will happen to mine if i use the wrong key......i got a new key made at Home Depot and i didnt know it was a security key....it would start then shut off after a while.....i never really noticed if the fuel gauge moved during my issue...
Old Sep 6, 2019 | 3:19 PM
Cliff1985's Avatar
My security light seems to be functioning properly only comes on briefly when I turn key on. No flashing or steady on. When I reset the computer it might run fine for up to ten minutes and while it is running fuel gauge reads normal. Fuel gauge pegs out just a split second before engine stalls. Also upon online investigation the security system will only kill fuel pump, not ignition coil supposedly
Old Sep 8, 2019 | 11:01 PM
loopedr1's Avatar
most of the time when a gauge pegs on the dash it is grounded.....thats how you usually check to see if a gauge works.. you ground the signal wire and watch the gauge peg.....you may have a ground problem with the tank sender and pump...
Samantha Micelli
Aug 18, 2016 9:59 AM
chris 419
May 18, 2013 10:29 PM
JEFFSW31
Aug 12, 2009 4:09 AM
JEFFSW31
Aug 13, 2008 12:26 AM
strictly chevy
Jan 20, 2008 8:51 PM
