advice on high rev, cutoff issue
Old Jul 14, 2014 | 11:55 AM
garegin's Avatar
Default advice on high rev, cutoff issue
I purchased a Chevy Express 1998 5.7/350 V8, but the owner says the car has the following issue.
The car rev too high when idle, and sometimes cuts off completely when put into neutral. He changed the mass air meter sensor and the air intake sensor, but no avail. What do you think the next step should be. Should I just take it to any mechanic, or should it be one who specializes in specific parts (engine, transmission, whatever).
I don't know much about cars, so I'm just trying to get a basic idea.
Old Jul 14, 2014 | 12:15 PM
Welcome to the forum...
Have you check for vacuum leaks at the intake? checked vacuum lines and the brake booster?
Old Jul 14, 2014 | 3:47 PM
garegin's Avatar
yes he did.
Old Jul 14, 2014 | 4:58 PM
I would do a double check with some carb cleaner, with the engine running spray in sample spots to see if the idle changes with the spray to gasket areas and vacuum fittings....
Make sure the throttle linkage not hung up and moves freely
check the idle air control valve for proper operations
Old Jul 14, 2014 | 6:41 PM
wgander's Avatar
Use an OBD reader to see if there are any codes stored...
barellies
Jun 13, 2011 9:49 PM
mirage00
Oct 21, 2010 10:32 AM
T_D_H
Aug 19, 2009 9:58 PM
Xieon
May 16, 2007 12:19 PM
TexPhoneGuy
Apr 17, 2007 1:00 AM
