Alternator Output
Old May 3, 2021 | 10:29 AM
funtwodrv's Avatar
Default Alternator Output
Okay, so is there a way to test the output of the standard 105 amp alternator using just a voltmeter? We have a 2014 4500 cut away van chassis. It appears this has a "smart" charging system that varies the voltage based on need. The battery is reading 12.6 after sitting for a day or so. With the engine running, I see 13.2 to 13.6 on the voltmeter. Engine speed does not seem to influence this voltage. The dash gauge is indicating a tad below 14.
Gary
Old May 3, 2021 | 1:40 PM
oilcanhenry's Avatar
Gary
Sounds pretty normal to me. I don't think you have an issue at all.
Old May 3, 2021 | 11:42 PM
If the truck starts every morning then there's no need for concern.
Old May 4, 2021 | 7:03 AM
funtwodrv's Avatar
Great...Thanks for the input.
Gary
Old May 4, 2021 | 9:25 PM
William Kisselstein's Avatar
It's always going to put out the same voltage if it's working right, and it will be a tad over 12 as you're finding.
The difference would be in the amps coming out and you'd need to set the meter to measure that.
Old May 4, 2021 | 9:51 PM
Nope. funtwodrv is correct. Smart charging systems vary the voltage.
redboy
May 17, 2021 9:01 PM
2001chevysuburbangray
Apr 10, 2020 1:28 PM
luckychicago23
Feb 26, 2013 2:54 PM
99SuburbanTX
Sep 13, 2012 9:34 AM
baskervi
Jan 15, 2011 11:02 AM
