Best up grades done
#472
#473
Just a thought cause I am gonna order my Running boards but with that 3 inch lift and the tire size.... that is a Big first step to get into the van.
Looks like your van has ground effect package.... im not sure but can you add running boards with those on the van ?
I know its tough for my wife of 5ft 4 to get in....
I couldnt imagine another 3 inches with out some type of assistance ( step board ) ( running board ).
#474
Running Boards Express Van
These are the ones I am ordering
https://runningboardwarehouse.com/shop-by-vehicle/chevy/express-van-g-van/2003-2018-extended-4-door/luverne-7in-textured-black-grip-step-running-boards-415114-401346.html
These are 114 inches long by 7 inches wide.
#475
Clearly, you are not a member of the Barefoot Nation. And yes, it already is a climb up into the van. I think my running boards were probably the best thing I did to Le Moose. By spring, I'll be adding some ground lighting LEDs underneath them. I have white ones that will be wired to the doors, and some RGB to add some color, that will be manually controlled.
#477
STAN...
What I have noticed with all conversion vans they have them... kinda like a signature....
They are offered to buy seperatly.... but its a cool factor more than anything.
#478
Well, if they do allow air to flow through, it might help. One thing I've noticed with Torque is that mine runs a tad hot (203-204). But it also might be cool to put some LEDs behind it for added color.
#479
Side Fender Vents
STAN
here is a link to the vents and they might be functional...
a call to the manufacture may be in need for the answer.
Custom GMC Van 2006 Side Vents - Sarona
