Blinking Head Lights
Old Aug 30, 2014 | 3:44 PM
skppie's Avatar
Post Blinking Head Lights
Have a 2001 Express Van diesel when I start it up the daylights blink off and on and the headlights dim but when I turn on the headlights switch they stop blinking, when I turn on my high beams they will blink off and on until I turn off the high beams. Is it a short or a relay that is bad?
Old Sep 9, 2014 | 5:44 PM
pwf16129b's Avatar
sounds like a ground problem had a van years ago doing similar had to run an extra ground to fix it
Old Sep 10, 2014 | 6:46 PM
skppie's Avatar
Thank for that advice now how did you run the new ground?
Old Sep 11, 2014 | 8:09 AM
pwf16129b's Avatar
Default ground
i went from the header panel they are mounted in to the battery built a 10 gauge wire with a terminal end put under a bolt and run back to the battery and connected to the pigtail on the ground.
i am prone to removing the stock bolts at the battery and using a 3/8 bolt and nut so i have somewhere to hook up extra wiring if they don't have an extra wire there stock
Old Sep 12, 2014 | 10:35 AM
skppie's Avatar
Thank you I will try that.
trryhmmnd
Feb 4, 2025 8:23 PM
Damondogg
Nov 4, 2014 5:59 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
tpdon
Nov 17, 2011 10:24 PM
KonaBurb
Mar 6, 2007 7:18 AM
