blower motor runs when engine is turned off
Old Jul 13, 2010 | 9:31 PM
erasbar's Avatar
Unhappy blower motor runs when engine is turned off
i just noticed today, i have a 2002 chevy Express 1500, the van was parked and the blower runs randomly without the key on the ignition
Old Sep 5, 2011 | 3:00 PM
domenic72's Avatar
hi i just wanted to know if you found the problem. because i'm having the same problem with my van.
Old Feb 10, 2016 | 1:18 PM
Jeremie's Avatar
I'm bumping this thread as I am experiencing the same problem. The battery was completely dead and when I try to charge it I heard the blower but it was on/off as the battery charge was overloading. I just remove the 60 amp fuse just to let the battery charge but it will need to find the problem anytime soon.
Old Feb 10, 2016 | 2:55 PM
canucklehead's Avatar
That is odd. It should not have power. Is there a relay that is stuck?
Old Feb 10, 2016 | 3:01 PM
I checked online and the resistor is stuck, and it needs replacing.
Here is a link.
2004 Chevy Express van .. Blower motor runs all the time ..
Old Feb 10, 2016 | 5:37 PM
Jeremie's Avatar
Here is a link.
Thank for your advise I will look that tomorrow. I will put back the fuse and unplug the blower resistor. At least it not too expensive and it and easy job to do.
Old Feb 17, 2016 | 5:19 AM
Jeremie's Avatar
I change the blower resistor. Took me 15 minutes to do because I had to modified the hole as they change the part design and now everything work fine.
Old Feb 17, 2016 | 12:08 PM
Sweet.
khaugie
Feb 4, 2024 6:41 PM
nickyb
Jun 12, 2014 9:05 PM
hatchet
Nov 27, 2011 8:21 PM
jessejoe23
Nov 14, 2011 9:35 AM
chevydevildog1890
Jun 5, 2010 1:39 PM
