Brake boot tip?
Old Jul 28, 2021 | 2:29 PM
Kael's Avatar
Default Brake boot tip?
Replacing all the brakes on my 2005 2500, ran into what should be a simple thing to address. I must be missing something obvious (I do that all too often). Any pointers?
Issue is the rubber boots on the pistons. I checked the refurb brakes I bought and sure enough, they weren't greased worth a snot. Fronts were easy with that plastic ring holding the boots in place. The rears are a different story, I can't get the outer ring to secure in the caliper. I found a bit describing getting air vented out of the boot when installing, no luck there, the darn thing just isn't going in. Tried using a thin-ended tool from an interior maintenance tool, no luck. Fingers, no luck.
Old Jul 29, 2021 | 2:31 PM
Kael's Avatar
Ah ha. Second duckduck search finally showed a useful youtube:
In short, have the boot on the piston towards the back so the bits that mount in the caliper are hanging off the edge, with the front portion extended. Then insert the boot/piston, starting with the bottom and get the back in place, carefully to keep the front from sliding around. Then insert piston.
First try, boom, done. Second, got it after some cussing.
next2nothing000
Oct 10, 2021 9:25 AM
bluerado04
Nov 10, 2014 12:09 PM
lromme
May 17, 2011 3:10 AM
oniondip
Feb 3, 2010 5:23 PM
Nicaraguense13
Dec 4, 2007 1:03 AM
