Brake light on dash help please
Old May 10, 2020 | 9:03 AM
Anthony Emreson Smith's Avatar
Default Brake light on dash help please
Hi struggling with brake light on dash on my 2004 .3500 express campa tryed level switch and park brake switch both ok what else is in circuit thanks in advance
Old May 10, 2020 | 9:38 AM
Triaged's Avatar
There might still be a pressure balance switch that tells you if half (front or rear) of your hydraulic system. Could be an internal leak in the master cylinder if that is the case. With all the electronic stuff though you likely should get a scan tool on the ABS.
Old May 10, 2020 | 9:44 AM
Thanks will check for a biased valve in brake line .hope to get scan tool sometime next week but on lockdown
Old May 13, 2020 | 1:59 AM
Originally Posted by triaged
there might still be a pressure balance switch that tells you if half (front or rear) of your hydraulic system. Could be an internal leak in the master cylinder if that is the case. With all the electronic stuff though you likely should get a scan tool on the abs.
sorted now abs pump us thanks for the help
khali20830
Aug 23, 2014 8:27 PM
R.R
Dec 28, 2013 9:36 AM
jrsavoie
Jul 19, 2012 2:36 PM
bkordrs
May 15, 2011 11:05 AM
hatch92
Jul 3, 2006 10:45 PM
