Brake Pedal Feel 1999 Express Conversion
Old Jul 23, 2023 | 8:40 PM
Skyhawk1961's Avatar
Default Brake Pedal Feel 1999 Express Conversion
1500 version. It has the 5.7. The brake pedal feels a bit stiffer than I thought for power brakes. I know these have drum rears. Anyone else have this issue? Its not extreme and dosent feel unsafe..just a bit stiff.
Old Jul 24, 2023 | 9:19 AM
Triaged's Avatar
It could be one of 2 things. The brake booster, or the brake pads. Look up DOT Edge Codes and you will see that there can be a huge range in friction. Some "fleet" type heavy duty pads have very low friction causing more pedal effort. Brake booster should give you a couple of assisted presses once you shut down the engine.
Old Jul 25, 2023 | 8:20 PM
Its only got 37,000 miles so I'm pretty sure the OEM pads and shoes are still on board. I will need to pay more attention to your brake booster suggestion.
jerrygoodwin
Oct 1, 2021 1:26 AM
motc7777
Jul 22, 2021 4:29 PM
tmise
Jun 2, 2021 6:01 PM
Goochlin
Oct 4, 2018 7:00 PM
aubiexx
Aug 26, 2013 11:03 AM
