A/C not working
Old Mar 19, 2020 | 2:34 PM
garyj044's Avatar
Default A/C not working
I have a 1999 chevy G1500 express conversion van, a/c not working, it will work when i use a jumper wire on the drier clutch cycling switch. tried another switch still did not work. any ideas? thank You
Old Mar 19, 2020 | 2:41 PM
test fuses/relays
Old Mar 19, 2020 | 2:49 PM
garyj044's Avatar
are there any other switches other than the clutch switch on the drier that might be bad, and thank you i will check the fuses
and the relay
Old Mar 20, 2020 | 7:32 AM
Possibly low on freon.
Old Mar 20, 2020 | 9:10 AM
this!!!
if you are jumping a low pressure switch and it works...maybe you have low system pressure!
woodchipmaker
Mar 14, 2015 6:04 PM
birdieb
Jun 12, 2014 3:32 PM
max95
Jun 1, 2010 9:47 PM
fordchevy
May 21, 2009 8:57 PM
bwty
Sep 28, 2008 9:18 AM
