Cargo door seals (weatherstrip) for 96 - 02
I would like to replace the side cargo door seals on my 2000 3500 but not able to find part numbers online for the 1996 - 2002 models. Since the side cargo doors (hinged) seem to be the same part number from 96 - 01, I'm thinking the seals would also be the same. Is this correct? GM part number 15821952 is an example of a part that shows compatibility for 2010-2021 years and seems to look the same as what's on my 2000. This part has a molded end and also built-in clips for the lower section. Attaching pictures showing the seals on my van.
"n" shaped seal for entire side opening. Has molded ends attached.
Yes it fits
https://www.gmpartsgiant.com/parts/g...-15821952.html
Easy enough to find the part number (#3)
https://www.gmpartsdirect.com/v-2000...and-components
However, it is discontinued.
MasterofPuppets
September 9th, 2010 11:21 PM
ewatness
August 7th, 2008 12:15 AM
