Cat exhaust Diameter
Ok, I think it's 3 inches outside diameter, but can anyone tell me conclusively and without a doubt what the OD of the exhaust pipe is that feeds the catalytic converter and what size it dumps into. Not the cat pipe size, but the actual exhaust pipes leading into and out of the converter. I have to temporarily bypass what I think is a clogged cat on the driver side in order to get it to the shop. I live 30 miles into the country from the nearest shop and the thing just doesn't have the oomph to get it there. It's a 2003 Express 1500 4.3L
Thanks in advance
Thanks in advance
Thanks.
For anyone that needs the information: If you need to bypass the cat in such a situation as described, it uses a 2 1/2" ID pipe. I used flex pipe and in all the cost was about $9.00. This was for the pipe, which I got at O'Reily's Auto Parts (The national chain) and 1 clamp (1 clamp comes with the pipe and you need 2, so get a second one)
x_timewarfare_x
April 14th, 2014 9:08 AM
ericnottelin
July 2nd, 2012 10:03 PM
