Chevy 350 starting problems
Old Oct 24, 2009 | 10:53 AM
Johng_UK's Avatar
Default Chevy 350 starting problems
hi all, I have never been so desperate for ideas of what to check on my broken chevy
I will list what I know or think...
1984 RV _ G30 with a 350 Chevy engine. HEI ignition, Rochester Carb.
The van ran well back in September.. once it got hot it was running ok, cold starts were interesting... anyway, after a 100 mile journey, during the last 1/2 mile I noticed a fuel smell.. also, when the van was parked up, it 'ran-on' for the first time ever.. the temp was fine.
now I cannot get it to restart
I have checked the following
Compression - it is as it was a year ago, 150psi cold on all 8.
The carb has been off about 8 times, I cannot find anything obviously wrong.. I have checked float heights, compressed air through tubes, adjusted the electric choke it now has.. etc etc..
I have brought a known good HEi coil, and also the signal coil that triggers the main coil.. I really thought I had fixed it with that, last week it ran really well for about 20 mins, never been better...
but today, it did that and now has gone back to non starting again..
I have replaced plugs, rotor, distributor cap with new
I have checked the return fuel line is clear, and that the right amount of fuel is coming from the pump..
I beleive all Vac systems and being used or blocked..
It wont start, and when it did a little while ago, it threw a fair amount of vapour out of the carb...
so, it has fuel, compression, sparks, firing order correct, new coils and other electrical bits, choke is electric and the exhaust flange/cold start system ?EFE? is all back on and working..
what can I check now ? really stuck
John , England
Camero-mike
Apr 28, 2013 8:53 PM
ccnchevroletforum
Jun 21, 2012 2:43 PM
seankeppers
Jan 29, 2009 10:56 PM
hardwarz
Oct 16, 2007 11:54 AM
