Chevy Express 3500 4.8l to 6.0
I believe this should be a bolt-in swap, but you may need the ECU to make it run right.
As to the trans swap, that could be an issue if the plug is different, it would require changing both the ECU and the harness to the transmission, if that is a separate part and can be changed.
Pierre Daniel
December 26th, 2019 12:09 PM
LCAC_Man
25
December 18th, 2018 8:28 AM
