Chevy Express 3500 4.8l to 6.0
Old Jan 29, 2022 | 2:25 PM
shawner73's Avatar
Default Chevy Express 3500 4.8l to 6.0
I’m curious if a Chevy Express 4.8l is able to swap for a 6.0l? Are they compatible?
Old Jan 31, 2022 | 11:05 AM
ray caldwell's Avatar
Buy a wrecked one with engine and 4l80 trans to match
Old Feb 1, 2022 | 3:21 AM
William Kisselstein's Avatar
I believe this should be a bolt-in swap, but you may need the ECU to make it run right.
As to the trans swap, that could be an issue if the plug is different, it would require changing both the ECU and the harness to the transmission, if that is a separate part and can be changed.
Chad23jl
Jun 16, 2021 7:43 PM
Pierre Daniel
Dec 26, 2019 12:09 PM
LCAC_Man
25
Dec 18, 2018 8:28 AM
JD10
Jan 22, 2016 2:07 PM
2008express
Sep 28, 2011 5:00 PM
