ChuLai1
Old Dec 26, 2021 | 6:23 PM
ChuLai1's Avatar
Default ChuLai1
HI, new member,
I didn't see, or couldn't find my problem. I have a 2003 express 1500 4.3L V6. Been sitting in freezing weather 4/5 days and won't start. It chugs over OK, but not fire, or slight stumble. I check spark from coil to distributor; good spark. I put in fuel antifreeze couple day ago. No go. I have heated engine at distributor and fuel lines at back of engine, then sprayed starter fluid in intake as close to engine as possible. Still no ignition, a little more stumbling, but no go on starting. Wondering what you gentlemen think could be the problem, OR I"m the problem. Any help appreciated from Kamiah, Idaho. Thanks
Old Dec 29, 2021 | 4:08 AM
William Kisselstein's Avatar
1 - is there spark at the plugs
2 - have you checked the fuel pressure? Does the fuel pump run when the ignition is turned on (you should be able to hear it)?
3 - a scan tool with live data capability may shed light on the problem if you have spark and fuel.
I will give an example, my 2002 2500 would not start when hot when it was 80'F or more out; the culprit was a bad coolant temperature sensor which believed it was -68'. This had the computer adjusting the timing and fuel in such a way it would not start.
Were I to guess it may be a cap and rotor issue, but it could also easily be fuel pump or regulator.
jim_raynor610
Apr 3, 2022 4:16 PM
bat681987
Jul 14, 2015 10:14 AM
Igor_Kiforishin
Dec 10, 2014 3:34 PM
warthogcrewchief
Oct 5, 2014 12:56 AM
palmi
Aug 16, 2009 12:36 AM
