won't start
Old Aug 15, 2009 | 12:58 AM
palmi's Avatar
Default won't start
my 93 chevy c1500, 305ci won't start, no fuel no spark....... any ideas please....
Old Aug 15, 2009 | 1:07 AM
therewolf's Avatar
Does the engine crank like it's going to turn over?
Does the starter gear engage the flex-plate?
Do you see fuel spraying down the TB venturi?
Is the distributor bolted down tight? Rotor and cap dry and clear of tracking and cracks?
To be fair, we're operating in the blind here...
Old Aug 15, 2009 | 1:37 PM
lukemoore646's Avatar
they just need to have a no-start section, i bet it would be the busiest one, check your fuses first, it is not too common for no spark or no fuel at the same time, usually means no power to something
Old Aug 15, 2009 | 3:07 PM
palmi's Avatar
thanks guys. yes, engine turns, no gas coming out of injectors and no spark from coil(I tested it with ohmeter and it's ok), all fuses and relays ok, new fuel filter and pump. I'll try with new pick-up coil and ignition module in distributor this weekend, I hope this will solve the problem. Still like to hear more ideas that could help me with this problem. Thank you guys again.
Old Aug 15, 2009 | 8:46 PM
before you start throwing parts at it you need to check if there is power and ground where it needs to have power and ground
Old Aug 16, 2009 | 12:36 AM
palmi's Avatar
I checked all that, power and ground are good. the problem was in the distributor, ignition module and pick-up coil replaced and the truck is now runnig nice and strong. Thanks guys.
ZChevyAK
Nov 13, 2015 6:45 PM
daman77
Nov 14, 2013 6:53 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
