Click, tick noise coming from under the hood by the tension pulley
Old Jan 7, 2014 | 10:42 PM
Sebastian Saldana's Avatar
Default Click, tick noise coming from under the hood by the tension pulley
So i recently replaced my water pump, it was a success but now on idle my van has this click/tick noise near the tension pulley...
so i look under the hood...the van is on idle. I hear a click/tick noise once and the tension pulley moves up very little bit, not much but its noticeable...like 10-15 seconds go and it shifts back down....then maybe 30-45 seconds later it does it again...and again.
I drove the van and it seems to drive fine, no loss of power or anything, no check engine or anything
the tension pulley also does play a bit...not too much but it does.
Any ideas or the tick/click noise?
Old Jan 7, 2014 | 11:35 PM
Faulty tension pulley on 2000 Chevy express 1500 5.7? need help - YouTube
here is video of the problem...at the 9 and 18 second mark you can see it shift up a bit...it does it every few seconds, sometimes quickly, sometimes it longer between click/tick
Old Jan 9, 2014 | 8:38 PM
canucklehead's Avatar
The click on the video sounds like the ac compressor.....If the bearings in a pulley failed it would be more of a growl....
Old Jan 10, 2014 | 2:23 PM
tsbrewers's Avatar
That was my first thought too, it sounds like the AC turning off and on. It will kick on and off when the heater is on defrost.
FYCM27
Aug 28, 2015 5:42 PM
ihman
Jun 7, 2015 11:04 AM
sonic44
Dec 17, 2013 8:39 PM
j5403h
Jun 24, 2011 10:23 AM
midgard
Dec 5, 2010 6:47 PM
