Confusion - Condenser fan not running
Old Aug 17, 2021 | 2:33 AM
  #11
oilcanhenry's Avatar
Originally Posted by mx3500
Sorry i wasn't more clear - I was posting about a new problem. The condensor fan issue is resolved but after I turned the temp dial slightly toward red then back to max blue 30 minutes later, the compressor has been cycling on & off but only at speeds above 60 mph. In other words what I'm implying is by moving the temp dial while the a/c was on might have caused the mixer door to move back and forth at higher rpm causing the air vent temp to alternate cold air on/off as if the compressor is cycling on/off. Alternatively, the compressor is coming on/off only at speeds above 60 mph.
You said you are running 300 PSI on the high side. Although the system can handle that pressure at 75-80 F or so, it should be closer to 40-45 on the low side and 150-165 to 225-250 max PSI on the high side. Who did the work or add refrigerant to your A/C system?
Old Aug 17, 2021 | 1:27 PM
  #12
mx3500's Avatar
Never said my high side was 300.
Old Aug 18, 2021 | 1:49 PM
  #13
My mistake.My apologies for that..
Old Aug 21, 2021 | 5:14 PM
  #14
mx3500's Avatar
Today I connected the fan myself with a switch & inline fuse. The fan will reverse direction if the blue/black wires are interchanged but I have it connected to blow air through the condenser toward the radiator (same direction as radiator clutch fan). With the fan running at idle for 1-2 minutes the a/c air temp is not getting colder so it was a waste of time. If I rev up the engine to 2000 rpm for 30 seconds or more I can feel it start to cool down, with or without the electric condenser fan on, but that's a much bigger fan pulling air.
Old Aug 21, 2021 | 10:52 PM
  #15
r the fan shrouds in place...they gotta be there or the fan won't cool ship
Old Jun 30, 2024 | 6:58 PM
  #16
alphonse53's Avatar
You might be thinking inside a box. Have you thought about using an infrared tach to see if your compressor clutch is slipping? You should be getting liquid freon at idle if the compressor isn't cycling.
Jose V
Apr 29, 2021 7:57 AM
Aaron Davis
Uplander
May 9, 2020 6:20 PM
bojowaggie
Jun 28, 2016 9:14 AM
Kooshball1500
Apr 2, 2016 9:28 PM
the knight
Jul 21, 2007 10:10 PM
