Cruise Control Retrofit / Steering Wheel Questions
#21
I doubt the dealer will reprogram it for you, and I doubt an aftermarket stereo will respond to the buttons.
#22
I should beep out the steering wheel and the harness underneath the steering wheel when I have a chance, but I'm not even sure if they are simple switches or using a more sophisticated communication method.
#23
steering wheel
my truck is an 08 basline truck.i bought the steering wheel off rock auto.dont remember if it came with the internal harness or if i bought it off gmpartsgiant.com.i installed everything and the cruise worked without reprogramming.i install an aftermarket radio and had to buy an axxess module for the buttons to respond.now everything works and i didnt need to bring it to the dealer.now i cant speak for newer trucks .good luck!!!
Triaged (November 23rd, 2023)
#24
Hello, I own a 2012 express 3500 cut away. It does not have cruise control or radio controls. I have an aftermarket radio. Can I successfully put the steering wheel that has cruise control and radio controls on it and get the dealer to make the cruise control work and then make the radio controls work also? Thanks, John
I had to give the dealer the part number of the regular cruise control only steering wheel. When I gave them the correct (cruise control + audio control steering wheel) part number, they weren't able to reprogram it. My dealer charged me an hour of labor to reprogram the BCM ($170).
I never tried the audio controls before the BCM was reprogrammed, but I suspect they might have worked.
mountainmanjoe (November 23rd, 2023)
Asnyder
September 30th, 2015 10:12 PM
