Did they make a full floating dual wheel disc brake rear axle setup?
Old Nov 1, 2022 | 2:44 PM
G3500 Toy Hauler's Avatar
Default Did they make a full floating dual wheel disc brake rear axle setup?
I have a 2001 G3500 that I'm assuming has 411s. Currently my Cutaway has a full floating rear end. After completing what was close to a coast-to-coast trip - from east to west and back; I want to change the final drive ratio and while I'm at it - I wouldn't mind having rear disc brakes. Did they make a full floating dual wheel disc brake rear axle setup? IF NOT - What rearend can I get with dual wheels and disc brakes that will easily swap / fit my G3500?
Old Nov 1, 2022 | 3:49 PM
You don't have to guess. Check the RPO codes on the door jamb sticker.
I've never seen a van with factory dual wheels.
Of course you could look at a pickup truck donor, but it is my understanding that the van axle track width and offset is unique. This could always be checked with a tape measure.
easier said than done. it requires reprogramming of multiple control modules and finding someone who can do it. There's a topic about it somewhere in this forum section.
Old Nov 1, 2022 | 4:08 PM
Thank you.
I'll run outside and see what is still on the door jam.
As a reminder - I have a CUTAWAY = Cab and chassis. Van front cab and only a chassis for the back.
Old Nov 1, 2022 | 4:15 PM
Found the Code sticker on the passenger door jam. Now to find something online to help me figure out which one I'm looking for.
Found it - GT5 Axle Rear (Dup of GT8) 4.10
G80 is the next Code = Axle Positraction, Limited Slip
Old Nov 1, 2022 | 4:32 PM
Now to find out what the power band is for the 6.5... This is my first diesel and my last trip was a good shake down for my custom build.
Old Nov 1, 2022 | 5:46 PM
my bad I overlooked the part about cutaway.
well apparently it does exist ... at least in the 2019 GM Commercial brochure.
Not sure about brakes though. But realise that even semi trucks use drum brakes. I think they're just better for weight.
Old Nov 1, 2022 | 6:02 PM
I best not be looking at newer cutaways. LOL After building my first Toy Hauler - I now want a longer wheelbase, different engine and a bigger sleeper box. Grin
I have until next year to decide about the final drive and disc brakes. We aren't use to rust free vehicles here and I got this one from out west in 2019. So, I put it away for the winter.
case310350
Uplander
Mar 27, 2020 5:30 PM
ibgolfn
Nov 14, 2009 3:26 PM
bevnfred
Jul 26, 2007 8:37 PM
dmcgilvrey
Jan 29, 2007 6:59 AM
chevyjunky77
K5 Blazer
Dec 12, 2006 5:59 PM
