Driver door switch
Driver door switch
Where can I find the driver door switch, seems is malfunctioning. When exiting vehicle turn off engine remove key, radio
stays on! It’s always shut off up until this week. Only way I’ve found to make it work properly is to open passenger door, and it will then turn off like it should.
it might be the switch, or it might be the wires in your door harness, so do some troubleshooting first.
I'm sure the dealership has a new switch for you, as well as various GM parts dealers online, or the junkyard if you're ok with used.
Always post your vehicle details please.
It's probably integrated in the latch assembly. Check out charm.li
a website with service manuals for your truck
Kevakasper
September 24th, 2013 6:07 AM
Kahoutek1973
October 18th, 2011 10:10 PM
