Drum brakes
Does anyone have a diagram to put together drum brakes on an 88 G20 van? I need to replace wheel cylinders so I might as well do the whole job and I know the springs are color coded. The old hardware is rusty and crusty and it's impossible to see what color they are.
I was joking. They are orange every time you do rear brakes from the rust.....lol
Like above, go by the shape, and use one side as a reference.....besides If you pull both sides off, the wheel cylinder piston will pop out of the side you are not working on.....do one side at a time.
Actually, Iwill be replacing the wheel cylinders too because one of them is leaking real bad. Shoes are soaked in brake fluid. Parts will cost $47 plus the cost of turning the drums or replacing them.
