Drum brakes
Old Nov 14, 2015 | 8:40 AM
JIMMYDRIVER1's Avatar
Default Drum brakes
Does anyone have a diagram to put together drum brakes on an 88 G20 van? I need to replace wheel cylinders so I might as well do the whole job and I know the springs are color coded. The old hardware is rusty and crusty and it's impossible to see what color they are.
Old Nov 14, 2015 | 12:52 PM
canucklehead's Avatar
They are all the same colour....orange. Just do one side at a time.....use the other side as a template.....Take note that one brake shoe has more lining than the other.....
Old Nov 14, 2015 | 3:34 PM
the hardware kits I've bought before had springs that were different colors.
Old Nov 14, 2015 | 4:47 PM
go by the shape of the springs. if you have wear safety glasses wear them for this job.
Old Nov 15, 2015 | 10:39 AM
I was joking. They are orange every time you do rear brakes from the rust.....lol
Like above, go by the shape, and use one side as a reference.....besides If you pull both sides off, the wheel cylinder piston will pop out of the side you are not working on.....do one side at a time.
Old Nov 15, 2015 | 12:42 PM
Actually, Iwill be replacing the wheel cylinders too because one of them is leaking real bad. Shoes are soaked in brake fluid. Parts will cost $47 plus the cost of turning the drums or replacing them.
Old Nov 15, 2015 | 9:18 PM
edac's Avatar
One side at a time, use the other side as reference.
Old Nov 16, 2015 | 12:25 AM
I can do that but I plan on getting them both done while the drums are getting turned.
Old Nov 16, 2015 | 6:53 AM
Phillip123's Avatar
They're usually the same color, orange. Actually not usually but always So you should probably do one side at time and the other one can be your template.
Old Nov 20, 2015 | 10:27 PM
Pipedope's Avatar
Just take a few photos after the drums are removed & the shoe with more lining goes to the rear.
