Express 1997 crank no start
Old Mar 2, 2025 | 10:48 AM
nazqul's Avatar
Default Express 1997 crank no start
i have a chevy express 305 vortec from 1997 that crank but doesnt start.
I am out of ideas where to search.
the second problem is that i am from belgium so al the parts needed needs to be ordered thru rockauto or amazon
what i did is following :
  • new head gaskets
  • refurbishment of the heads
  • new timing chain
  • new bolts, gaskets and al the hardware that is needed.
The problem is that the engine cranks but does not start.
i checked everything double , timingchain, timing of the distributor etc
The spark is i think weak ( orange )
fuel pump is working. the fuel comes to the spider injectors but no fuel is coming out. ( no pulse ?? )
crankshaft sensor works but a new one is coming to be sure
the car doesnt react on spraying brake cleaner in the intake
Old Mar 3, 2025 | 1:26 PM
nazqul's Avatar
i am a little bit further.
i decided to start testing with the fuel system.
because the van is dual fuel ( propane is cheaper in belgium ) there is switch build in to chose which fuel i want.
that way i can run the pump continuous
i connected a fuel pressure gauche to the fuel line and that stayed on 0
when i was testing this i am hearing fuel splashing in the tank. thats weird because the fuel return line wasn't connected.
i thought f**ck, now i need to dismount the tank here on my driveway.
so i did
and my suspicions were correct. the inline tube was broken :/
Old Mar 4, 2025 | 11:31 AM
nazqul's Avatar
today i repaired the fuel pump.
now i have back the full 65 psi.
The van want to start but doesn't
tomorrow i gonna check the distributor timing
Old Mar 5, 2025 | 11:58 AM
nazqul's Avatar
now i dont now it anymore.
the van is still not starting.
it's just like the timing is complet offset
Anybody having tips for me
Old Mar 6, 2025 | 4:02 AM
nazqul's Avatar
the final update
setting the timing right like noted in the 1998_GMT-98_CK-3_SERVICE_MANUAL-VOLUME_3_of_4.pdf did the job.
The van fired right up and is spinning like a new one
Me happy
Old Mar 6, 2025 | 7:28 AM
jfmorris's Avatar
Glad to hear you got it figured out!
Seani
Dec 28, 2022 6:36 PM
Andew Reynolds
1988 - 1998 (GMT400)
Dec 17, 2020 11:17 AM
Southaven
Jun 2, 2017 11:29 PM
MET-TECH
Oct 20, 2015 12:44 PM
Doug Wells 69
Aug 31, 2013 12:54 PM
