Express Rear Blower Motor Replacement
Old Jul 28, 2023 | 8:25 PM
middamiff@hotmail.com's Avatar
Default Express Rear Blower Motor Replacement
Hello… does anyone know how or can anyone provide a link to how one replaces the rear blower motor in a late model Express factory rear air module? My manual doesn’t say much and I am unable to find any definitive instructions on the internet. I searched this forum with no luck. It appears that all of the housing screws for the removal of the cabin-facing half go in from the back side (between it and the body) or the bottom which appears to make it impossible to remove without removing the entire unit which requires a full evacuation and recharge. I haven’t tried yet, but I wonder if loosening the mounting bolts may provide enough wiggle play to pull it out and reach the back screws. Any help is much appreciated. It’s HOT here in AZ and that rear air is mandatory. Thanks!
Old Jul 28, 2023 | 8:56 PM
there's nuts on the bottom exterior of the van bolting the whole thing to the floor. Undo those and there should be enough play to get to the back of it.
Old Jul 28, 2023 | 9:05 PM
Thank you very much. I was hoping that might be the case but wanted to see if anyone had actually done it before I spent a lot of time in 115 F experimenting. I’ll try to see if I can do it tomorrow and will report back. Thanks again.
mark6747
Dec 22, 2015 10:31 PM
bluegold
Jul 27, 2014 7:03 AM
nickyb
Jun 12, 2014 9:05 PM
TahoeLTGuy01
Mar 17, 2014 9:25 AM
Trbohead
Aug 18, 2009 7:44 AM
