Express will/will not start. Fuel Pump problem..
Do yourself a favor and try the easy stuff first. I was about to drop the fuel tank in my trusty old 1996 express 1500 when I discovered a dirty connector.
I had recently replaced the oil pressure sender which blew through with oil and indicated zero oil pressure. A few months later the van died a few times with no fuel pressure. I put a paper clip across the oil pressure switch connector and the pump didn't turn on even though I measured 12 volts at the paper clip. I either had a bad pump or bad wiring to the pump. I pierced the wire in the harness about a foot from the pump to check the voltage, and while I was messing with it the pump turned on. Sure seems like a bad connector now. Fortunately I was able to reach the connector on top of the tank so I pulled and cleaned it with tuner cleaner. The van started right up and ran down to the end of my long dirt driveway and then it died in the middle of the road.
I managed to get it to start a few more times to get it back to the garage. While preparing to drop the tank, I went ahead and pulled that top connector off again and measured the voltage at the connector while the paper clip was providing the circuit from the oil pressure switch connector. Open circuit measurement was only 7 volts on the grey wire even though it was 12 volts back at the pressure switch. Now I knew I had a bad resistive connection, or splice somewhere. I traced the harness towards the front looking for splice S138 which seemed to be the only other link in the chain. In the diagrams, the connector on the top of the tank appears to be C301, but there is actually ANOTHER connector attached to the front of the tank, very exposed to the elements. THAT one is C301. I pulled it apart and it looked OK, but the contacts were a little dull as compared to the other one. I sprayed the heck out of it with tuner cleaner and shoved it in and out about 10 times, and now I have a solid 12 volts Van runs like a champ now. So glad I checked the voltage again before I started shot-gunning parts. I wish these GM wiring diagrams referenced the actual connector and splice locations, that would save a lot of wasted time.
One more note. To make sure, I wiggled that C301 connector in front of the tank while the paper clip was running the pump. The pump would change sounds and cut out every once in a while which means the contacts are actually bad or a wire is broken. Guess I will have to actually replace the connector.
Thanks in advance
Yeah, the connector contacts were corroded and I decided not to replace it. Just using contact cleaner didn't work. I cleaned the female contacts with jeweler's screwdriver of the right size sprayed with contact cleaner and then used a heavy safety pin to shrink the contact hole a bit. I also scraped the male contacts really well. I plugged it in and out a few times and crimped the hole one more time. I tested it with the paper clip while shaking the wires and it sounded fine. It has been working perfectly ever since. It is in a bad place for road spray. I would recommend wrapping it with waterproof tape to keep out the elements. Also use zip ties to hold the tape and keep the connector in place.
Similiar problem here with suspected fuel pump problem. 2000 Chevy Express 3500, 5.7L. Started the van and it ran for 3 seconds and stalled. When I tried to restart I did not hear the whining sound from the fuel pump. I switched the starter relay with the fuel pump relay and still the same problem, so assume the relay is bad. I can not locate any fuse that is labled 'fuel pump' in engine compartment, so not sure if I have one. Where is that fuse ? An auto shop banged on the tank while trying to start - no effect. Shop told me the fuel pump needs replacement at a cost of $ 565 + $300 labor. Not sure if they were scaming me. So....any other way to check to confirm the pump is bad before I go replacing it ???
If you trace your problem to a bad relay you might want to review THIS post and consider filing a complaint with NHTSA (link in the post)
as this may be a defective part problem.
NHTSA can order a recall but there needs to be a number of complaints on file.
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
erosenwinkel
Sep 12, 2011 8:42 AM
hunter10220
May 18, 2011 8:37 PM
ross_boss08
Aug 4, 2008 2:41 PM
