G30 brake light issues
Old Jul 4, 2023 | 9:55 PM
Zman88's Avatar
Default G30 brake light issues
Hi all.
I have a 94 g30 that’s been converted into a school bus. I’m having some brake light issues. I have never had working brake lights on this thing. I installed new led brake turn reverse combo lights. Turn reverse and running lights work but no brake lights. I’ve replaced the brake switch, the dimmer switch and the turn/hazard switch. I’ve cleaned the engine block ground. Is there a relay or other switch that might be the issue?
thanks!
Old Jul 5, 2023 | 4:18 PM
Zman88's Avatar
Are there only 4 wires that control rear lights?
I have isolated the wire that lead to rear lights.
yellow
brown
dark green
light green
all wires get voltage for various functions except brakes. No wires get voltage when I hit the brake pedal.
Old Jul 5, 2023 | 5:16 PM
If you intend to do repairs on this van yourself, I highly recommend picking up some wiring diagrams, like a Haynes repair manual. Well worth the money.
Old Jul 8, 2023 | 8:31 PM
Zman88's Avatar
Is there a brake relay somewhere? If so, generally where is it located. I’ve torn the dash out trying to track this down and I found a relay tucked behind the gauge cluster. Is that brakes or headlights?
thanks!
Old Jul 20, 2023 | 9:58 AM
Zman88's Avatar
Reporting back on this, I solved the issue.
this is a bus conversion with a telma magnetic brake system. A wire from the turn signal switch was cut to signal the telma system. I repaired the cut wire now I have signal going back to the rear lights.
macbubba
Jun 11, 2023 10:39 AM
PatrykKoul
Apr 26, 2023 9:14 AM
jsp9r
Sep 3, 2020 3:54 PM
cooktruck
1988 - 1998 (GMT400)
Aug 5, 2016 9:26 AM
baldwincole
Jan 7, 2012 7:00 PM
