brake light issues
Old Jan 5, 2012 | 7:49 PM
baldwincole's Avatar
Default brake light issues
when i noticed issue i had to have pedal compressed fully to have brake lights..so i installed new brake light switch and worked for a while..i again replaced switch thing i purchased a faulty switch after installing second switch i have no brake lights.. all others work blinkers,haz,backup.. i do have power to brake switch just no lights.. if i use my controller and slide it the brake lights work..ive heard that the multifunction switch(turn signal) would cause this issue any help would be great thanks
Old Jan 6, 2012 | 10:33 PM
lsylvain's Avatar
Pop your hood and listen for a "click" when you tap the break. You might need a new relay. When you hit the break does it activate you controller, could be the conection there is bad. hope this helps.
Old Jan 7, 2012 | 7:00 PM
ive come to belvee its the multisystem switch (turn signal) haven't installed yet. will keep posted and any other thoughts would be great..
justmike
Jan 17, 2014 10:10 PM
stevenf
May 6, 2013 11:41 AM
beckya99
Jul 12, 2011 12:29 PM
ricky
Feb 4, 2011 6:50 PM
mike79K5
May 29, 2009 7:42 PM
