Folding down rear seats in a g20
Old May 25, 2016 | 9:37 AM
Emitchellll's Avatar
Default Folding down rear seats in a g20
So in my 1990 g20 van, there is an electric motor to fold down the rear seats into a bed. However recently, it stopped working. Is there a way to put these seats down manually or will I have to replace the switch or the motor? I would really like to be able to just put them down on my own.
Old May 25, 2016 | 10:04 AM
I really need help with this. I bought this van essentially to live in and for camping purposes and if I can't get the rear seats down, that would be a huge problem. Please help. Thanks!
Old May 29, 2016 | 10:24 AM
solwav's Avatar
What diagnosis has been done, the issue is probably simple have you tried to power the motor directly to 12V? Four things come to mind 1) the fuse is blown, 2) no power reaching the switch, 3) switch is faulty or 4) the electric motor is bad.
Old Jun 5, 2016 | 7:09 AM
awelder's Avatar
My express conversion van has one of these. I found four relays over by the rear a/c. I am assuming they are for the bed, so you might check for those. I have four as my bed slides front and back as well as reclines up and down. Good luck.
Old Jun 14, 2016 | 2:45 PM
JIMMYDRIVER1's Avatar
I agree with solwav. bench test it first. Salvage yards might have some used stuff in a van that's compatible. Otherwise some weekend engineering and you can make it work manually. I got a fold down back seat in my 88 G20 that isn't motorized but it has a bar that runs head to toe under the cushion that makes it impossible to sleep or do anything else on.
Old Oct 30, 2018 | 4:20 PM
Jimbob85's Avatar
To actually answer the question. Yes. You can recline the back seat without the motor. You would have to detach the cables that recline it. Then you can just grab the back of the seat and pull it down.
Old Oct 31, 2018 | 2:57 PM
StanVan's Avatar
15 Year Member
You just answered a two year old question.
Old Dec 6, 2020 | 5:51 AM
David Oliver's Avatar
so? It’s a good question. Others may be looking for answers besides the op.
Old Sep 9, 2021 | 12:51 PM
79 Truckster's Avatar
Your answer helped me in 2021. I appreciate you responding to a “2 year old question”
Old Oct 15, 2025 | 6:20 AM
inkCity's Avatar
Default Honestly. Ty
an answer to the years old question. I knew you could. I read it somewhere and came back around. Thank you for kindly spreading the word.
Cheers
Altered4x4
31
Mar 23, 2021 4:51 PM
Max Vaysburg
Apr 4, 2017 11:40 AM
kmalibu79
Mar 3, 2017 12:00 AM
dan_i_hansen
Mar 9, 2015 4:50 PM
TheexpressVan07
Sep 14, 2014 2:36 PM
