Fuel line replacement
Old Feb 10, 2020 | 12:16 PM
Ron6519's Avatar
Default Fuel line replacement
I need to replace the fuel line on a 2001 Savana 2500 5.0 liter van. This is the line from the fuel pump tp the filter. I can't find any vendor who carries it. Rock auto carries the set for a 155" van, but not for the 135" one. Can I just make this or are they preformed to conform to the route between the pump and the filter.
The current ones are plastic. Can I switch over to another material and still connect to where I need to? Concerned about the connector compatibility.
Thanks
Ron
Old Feb 10, 2020 | 12:29 PM
Amazon Amazon
this is what a shop would use to make new lines. you buy the quick connect fittings and the tool pushes them into the bulk plastic line. a less better and more expensive method if the fuel pressure is around 45psi and lower; you can use rubber fuel line and fuel line hose clamps.
you can also buy plastic to plastic, metal to plastic and metal to metal unions to join mixed materials
Old Feb 11, 2020 | 9:46 AM
Ron6519's Avatar
I need to get under the van to check for clearances. As I remember the space is tight. I'm thinking of getting a nylon kit and use internal couplings so the tightness of space wouldn't be an issue. Looked at a few videos after posting and did some research online as to what was available.
Thanks for the info.
Ron
graybeard47
Mar 20, 2019 2:32 PM
dusted
Sep 12, 2018 7:15 PM
Hopwall765
Apr 16, 2018 10:52 AM
W1KKED1
Oct 30, 2014 10:27 PM
NMguy
Jan 28, 2012 12:16 AM
