Fuel pump?
Old Sep 22, 2020 | 9:29 AM
Brailediver's Avatar
Default Fuel pump?
I have a 2001 express van with 5.7. It misses at idle. Not an ignition problem. Pump pressure is 60 when you turn the key on, drops to 52 when running. Seems to run fine at higher rpm. Just skips at idle. It was giving a po303 code, now it sets s p0300. Any suggestions? Does the pump need to maintain 60 psi! Thanks
dmpiatt
May 30, 2019 7:42 AM
1996ChevyTruck
1988 - 1998 (GMT400)
Feb 26, 2016 6:34 PM
lostinthewoods
May 8, 2014 12:19 AM
Drew Maughmer
Oct 24, 2012 8:13 AM
db13
Oct 23, 2011 4:41 PM
