G20 Automatic Transmission Range Selector Lever Cable
Hallo,
I have a late G20 5,7l and the Gear Selector can be move difficulty. I want to replace the Cable to it.
Is the cable still available? And how complicate is it to change?
I live in Germany.
Greetings and thanks,
Alex.
I live in Germany.
Alex.
Hi Alex. Please put your van questions in the van section, not S-10/Blazer. Thanks.
Moving thread ...
P.S. you should post the year please
Moving thread ...
Hallo,
thanks so much. I am a little bit confused. The description is showing a steel-rod, the manual is showing a cable.
Where is the rod used? Between cable and transmission?
Which transmission (type) has the 5,7l in it?
you're right the amazon product might be an aftermarket modification.
Check shop.advanceautoparts.com
https://blazerforum.com/forum/engine...e-years-95510/
