G20 Automatic Transmission Range Selector Lever Cable
Old Mar 28, 2024 | 11:27 AM
harrryharrry's Avatar
Default G20 Automatic Transmission Range Selector Lever Cable
Hallo,
I have a late G20 5,7l and the Gear Selector can be move difficulty. I want to replace the Cable to it.
Is the cable still available? And how complicate is it to change?
I live in Germany.
Greetings and thanks,
Alex.
Old Mar 28, 2024 | 4:56 PM
Hi Alex. Please put your van questions in the van section, not S-10/Blazer. Thanks.
Moving thread ...
P.S. you should post the year please
Old Mar 28, 2024 | 10:39 PM
It is a G20 from end of 1995. Thanks for moving in the right forum.
Old Mar 29, 2024 | 12:18 AM
Originally Posted by harrryharrry
Hallo,
Amazon Amazon
https://charm.li/Chevy%20Truck/1995/...ift%20Linkage/
Old Mar 29, 2024 | 10:24 PM
Hallo,
thanks so much. I am a little bit confused. The description is showing a steel-rod, the manual is showing a cable.
Where is the rod used? Between cable and transmission?
Which transmission (type) has the 5,7l in it?
Old Mar 29, 2024 | 10:39 PM
you're right the amazon product might be an aftermarket modification.
Check shop.advanceautoparts.com
https://blazerforum.com/forum/engine...e-years-95510/
Old Mar 30, 2024 | 10:59 PM
IO will look here... thanks so far.
DWB
25
Jan 16, 2025 5:04 PM
tree climber
Oct 14, 2023 2:14 PM
dtorres
Aug 10, 2021 8:31 AM
Ron_467
Apr 26, 2021 2:24 PM
Gwampa
Jun 13, 2009 12:29 PM
